Example: Say i have 4 moving heads in a line. I set the patern(macro) to circle, i want 2 of them to rotate counter-clockwise, and 2 of them to rotate clockwise, for a better effect.
It works fine when i create my own shape. However if i set the macro as the pre-made circle and then attempt to edit it and use reverse it does not work.
I suppose this is a bug or, just a limitation of the software?
