suidi 6c problem
User based support for the SLESA-U6 - SL512BC - developer kit
Gpaling
suidi 6c problem
Post by Gpaling »
hello,
i've just recently bought the SL512BC (siudi 6c) first i thought the sunlight didn't recognise the hardware,
but on dmxsoft is said that when the red led is blinking but the fixtures aren't receiving dmx the 8-pin chip needs to be replaced..
i find this a kind weird because i bought the hardware just 2 days ago.
is this normal?
please let me know
Gino Paling,
Holland
Re: suidi 6c problem
Post by bruno.falip »
The green LED must flash very quickly when the interface is recognized by the software. Plus, you should be able to read "1 SL512BC" on the lower-left corner of the software startup screen. If it is not written then the interface is not recognized and you must check if the USB drivers are correctly installed.
