Need REAL slow scan movement...
teggers
Post by teggers »
I will do a search later tonight on this question, but I need to slow down the fade time REAL slow so the lights will scan the room with logos. I was using the automated settings but was unable to slow them down as much as I needed. I had to actually use a manual controler (and not use the software) and program that with a fade slider to get by.
How do I edit the "fade" of the pre-generated scenes/chases so the lights scan REAL slow?
Thanks, Tim Eggers
Guest
Post by Guest »
You must:
1- Edit the scene
2- Right-click on the shape area
3- Select "Shape properties..." from the menu
4- Go to the "Time" tab and select a longer time for the steps
teggers
Post by teggers »
Thanks so much.....works like a charm....
I knew it was easy but with a show going on and all....forgot where that setting was.
BTW, can I alter the settings of all the time lines by multiple selection of the fixtures - or do I have to edit all of them - 1 at a time?
